RE: Strength of signal and 3IM
Oops... very sorry, I goofed. Thank you Phil. Please disregard my previous post (as Phil says, you can use MHz or Radians per second or whatever, as long as you are consistent and the units are 'linear' (our channel numbers are ok since they are evenly spaced).
So we are speaking of third-order (or 5th or 7th, ...) IM. There is a possiblity of interference except that the transmitter will be much stronger than the IM source. Typically more than 60 dB (one million) times greater and more likely 100 dB. Would you all agree?
