RE: Adding series batteries and flight time?
I follow What he is getting at. If you have 2 1 gallon cans of water connected together and put a 6mm hole in one it takes 1:00 minute to drain, 0:30 seconds a gallon. If you connect a 3rd gallon should it not take 1:30 to drain from the same 6mm or 6 amp hole.
It confuses me also. Help us both understand, I know the knowledge is out there
JimB
