RCU Forums - View Single Post - Aerohawk initial setup
Old 04-11-2004 | 06:25 PM
GREGF
Default RE: Aerohawk initial setup
First thing you should do is make sure the head is free to move. It should flop from side to side with no lock ups. You will need to sand down the parts that make up the head to ensure free movement.
The ball joints that go up tothe fly bar should also be free to move. I found that putting some tooth past on the joint and moving it round for a bit did the trick.
