RE: Hangar 9 Twist 3D
I agree with P51. The holes are pre drilled and line up very well. I did have to make a minor adjustment to get the elevator halves level, but all it required was test fitting and making a very slight bend in the joiner wire. The vertical stab alignment was right on with no adjustment required.
Thanks for the explanation on the prop Bama. I was thinking of using a lower pitch prop myself but I wasn't going to go over 11" on diameter so I can keep my ground clearance (Just in case the landing gets a little rough [:@]). Let us know how the new prop works.
