How many servos on Supreme Rcvr?
Mike, I'm well along in building a four engine flying boat (124" span). I will be using a Supreme 8 channel receiver and this servo set up - 3 HS-635s (one on rudder; two on flaps) ; 4- HS-475s (two each on elevator and ailerons) and 4 _ Fut S133s (throttles) on five cells. Would I be OK running all the servos through the receiver or should I power them from a separate bus? I may run a switch as well for separately powered lights. This is a scale project powered by four OS52s so there shouldn't be any severe flight loads on the control surfaces.
