RCU Forums - View Single Post - Hype 3D
Thread: Hype 3D
Old 04-19-2004 | 06:47 AM
Ingie
Default RE: Hype 3D
Iv contacted about 3 model shops and they all say th hype is out of stock!!!! im gonna keep lukin though i think itll be bout 2-3 weeks before nyone has a kit instock![]
In the meantime though my dad is learning to fly with a variation of a limbo with control surfaces about half the size and movements of about 5mm so ill set that up on a different model memory on my FF6 and try to learn to prop hang. (with loads more movement)
I'm glad to hear some of my standard gear is okay to do most 3D moves, although to upgrade to a new engine especially the Weston .50t1 would be pricy! being 14 i'm on a strict budget! The purple pipe on my SC only had 2 flights before the pizzaz crashed! so if i did get a weston id still be using th purple pipe!
Ultimate, if youv'e flown/own a hype whereabouts is the best C of G for basic 3D manouvers?
Welsh3D, are you the webmaster at www.3drc.info? Because that is an increadble site!
Sorry about your Interference problem and all the lost models ZepPilot!
Ingie
