RE: Hangar 9 Twist 3D
I mounted my elevator servo on the right side and the rudder on the left as you suggested. It just seemed logical to me and it works fine. A problem I ran into is the blind nut in the fuse for the wing hold-down is stripped. I found it when I tried to tightened the nylon screw down and it would not tighten. I first thought the nylon screw was stripped but on closer inspection I found the blind nut is stripped. It is just a 1/4 20 nut, so that is not a problem, but so far I can't get the old one out. It is glued in pretty good.
Ron
