RCU Forums - View Single Post - adjusting 3W50i
Old 04-22-2004 | 07:15 AM
OSilfa's Avatar
OSilfa
Default RE: adjusting 3W50i
If you 3w50 is the new model with the new ignitions the ajustment of the needle is
H=1 turn out
L=1.1/4 out
You have to wait that the engine take temperature for the adjustment, run the engine for 3 0r 4 minutes then make the adjust.When the engine is cold have a little lag in the transition from mid to high like lean this is normal
you can check in this link http://www.3w-modellmotoren.com/engl...toren_com.html in the seccion of engines basics settings.
Oscar Silfa
