RCU Forums - View Single Post - JR8103 Programing
Old 04-25-2004 | 08:17 AM
Chris True
My Feedback: (14)
Default RE: JR8103 Programing
ORIGINAL: Alex Wenzl
I've found another way!
Program mix 3: aux3-aux3, rate on top 0%,rate on bottom Plus 100%,sw:land.
program mix 4: aux3-aux3,rate on top 0%,rate on bottom -100%,sw:ele>f.
travel adj: aux3 0% top and bottom.
I'll then put a drop of glue on the aux 3 knob to keep it from moving and use my flap mix for the turbine activation. I perfere this setup so that in an emergency I can shut down the turbine real fast.
Tanks for all your help,
Alex
You can set the input for spoiler to "Mix" or "Pot" on the main menu, that might remove the need for the glue?
