RE: Routing Ideas??????
Well we all have different ideas on this subject. I run all my wires on the bottom of the outside of the fus. On the WH Edge, I drilled a hole in one of the supports, ran the antenna out the bottom and covered it with yellow electrical tape. cannot see it even if you look for it, and it is not close to electronics.( servos & wires.) Also, if you ever do have a problem with your Rx, it is very easy to remove and replace without threading it through a tube that MUST be fastened to the fus for obvious reasons.
