RCU Forums - View Single Post - Ram 750F ECU
Thread: Ram 750F ECU
Old 04-29-2004 | 05:00 AM
geneh-RCU's Avatar
geneh-RCU
Default Ram 750F ECU
Where can I get a Ram 750F ECU repaired? Is Bob Price still around? For some reason the ECU looses the information that it stores when I do the Setup to the transmitter ad the turbine sputters and I get some smoke ( Like too much fuel) from the exhaust. When I set the ECU up for the tx again the problem went away until I shut the ecu off then it lost the settings and on the next start it went back to sputtering again on throttle up. On one start it started Ramping and then said throttle low and shut down. What do you people think? Does the ecu store the data in non volitale ram? or is there a small watch battery in the ecu used to keep the settings?
Thanks!
Gene
