RE: Ram 750F ECU
I have the older ECU. I will contact Andy or RTI. I think that the problem is the ECU because when I set it up again to the TX the then engine ran fine but when i turned it off and tried to start it later it was acting up again. Also I have seen the display read LOW THROTTLE while ramping up but it still ran.
Gene
