RE: Rudder Coupling Causes & Fixes
You'd be surpised, but no, it's not as far back is it could be... Normally this would aid in 3D manouevers, but this bird just does it somewhat naturally... Flying at half throttle she floats nice and straight with the elevator perfectly centered and very little trim...
I'm going to attempt to make the fuse equal on both the bottom and top doing what you recommended. I should have the results by the weekend... Do you know what is happening to the air as it passes the control surfaces to cause the tucking????
