RCU Forums - View Single Post - Replacing a .40 engine with a .60 in a Trainer
Old 05-01-2004 | 09:08 PM
FHHuber
Banned
Default RE: Replacing a .40 engine with a .60 in a Trainer
I have set the throttle linkages to prvent the throttle from going to 100% before.
Generally this sounds like a good solution... but if you need to tune the engine, you can not easilly retune the high range.... you have to over-ride the limit so you can get full throttle in order to do the retuning correctly.
