RE: Saito .72 and Horizon Hobby Twist
Lefty,
Here are the pics..........hope they come over ok. The exact location of the hole thru the firewall can be altered somewhat, maybe a little lower etc., depending on which hole in the throttle arm you decide to use. You will also have to enlarge the throttle arm hole slightly to accomdate the 2X56 rod. I would also encourage the use of the plastic tube for guiding the throttle rod. Unless someone else comes up with better suggestion I will probably give this setup a go. Let me know if you have other thoughts.
Lobob
AMA #808252
