RE: C160 transall build
Dnts,
Sounds good! I will be running either 9x5 or 9x6 APC props, I thinks the 9x5's will probably work best as they won't cut as much air. I plan to have a good look and think about retracts, but I won't know if it is possible until I get the kit. Which I'm despiratley saving for!!! Have you got any pics of the new bird? What did you do to fix the nose gear problem? Is it worth doing before flying? What hardware did you replace?
