RCU Forums - View Single Post - LT-40 is underway
Old 05-12-2004 | 01:00 PM
N8theSk8's Avatar
N8theSk8
Default RE: LT-40 is underway
You should be ok. It should also fly well. Just continue to practice not using alot of CA. And fight the urge to go faster. If you need a longer setup time to get things lined up, you can use thick CA, wood glue or some of the glues mentioned on RCU that take a little longer to setup.
