RE: HELP LEARNING TO TAKE OFF WITH TAILDRAGGER???
If the gear was toe out, and if possible, you can take it off and mount it the other way around, which will make it toe-in. I've seen a couple of planes where the builder put the gear on backwards, resulting in bad ground handling.
