RCU Forums - View Single Post - EVO 46
Thread: EVO 46
Old 05-21-2004 | 11:08 AM
jettstarblue's Avatar
jettstarblue
Default RE: EVO 46
ORIGINAL: Montague
Wayne, you quoted number for the "trainer power system" Believe it or not, the TPS Evo and the Evo .46 are NOT the same engine. They are very close, but they have slightly different displacements. I haven't taken each apart to compare them, but I'm going to make a guess that the porting on the TPS is more conservitive to result in more torque and easier starting and idle handling, while the .46 is more aggressive, resulting in more power and higher peak RPM.
Well alrighty then I stand corrected, now I've got a question- which engine comes with the "Arrow" from H-9? Is it the .46, or the TPS?
At any rate, I'm happy with both the engines in my Alpha, and my Arrow. They are both real good, easy starting, more than adequate engines.
Jetts
