RCU Forums - View Single Post - Spacewalker
Thread: Spacewalker
Old 05-22-2004 | 07:10 PM
mmiller1
My Feedback: (75)
Default RE: Spacewalker
Thanks Campy for the info. I finally re-read the instructions and for the most part they worked o.k. A bit tricky getting 2 pushrods to exit at the same time. I cut one threaded rod about 3/32" shorter than the other and took the long one thru first. Snaged it with some thread and held it out while the shorter one came thru next. I had to put a slight z bend in both rods but I am hoping that will not cause too much flex. True, goldenrod would be a bugger to anchor anywhere inside as this is an ARF. Appreciate your information.
Tim from Tacoma
