RCU Forums - View Single Post - Heli engine in plane?
Old 05-29-2004 | 09:17 AM
KW_Counter
Default RE: Heli engine in plane?
Guys,
A heli engine has nothing to do with its internals, it has to do with the externals.
The airflow in a heli is different so the cooling fins are shaped different to take advantage of it.
Will a heli engine work on a plane?
If in a cowl you are probably looking at overheating.
If completely exposed you will probably be OK.
I suggest talking to tech support at the manufacturer.
KW_Counter
