RCU Forums - View Single Post - What Hinges to Use
Old 05-31-2004 | 04:34 AM
spokman
Default RE: What Hinges to Use
The whole model is a lot of work. I think taking some extra time to do hinging is a good idea. Unless CA hinge manufactures post MTBF and other test specs on their hinges I'm not inclined to use them unless necessary. If you put a plastic, IE Robart hinge on properly you will have confidence that it will not fail. There are to many stories on this board about CA hinges failing.
