ORIGINAL: OldRookie
I tried the check valve thing on my OS 91FX. The pressure helps at at higher speeds. but when the engine is brought back to idle it would flood out. It seems as if a regulator of some sort would be needed.
I think I would also look at the clunk set-up first.
Greg
You will need to re-set your low speed adjustment.
