RCU Forums - View Single Post - Ever Get Stuck?
Old 06-15-2004 | 09:54 AM
FLYBOY's Avatar
FLYBOY
Default RE: Ever Get Stuck?
Hi Janet, good to see you back again. Its been a while.
I get burned out at times too. Usually I set the project aside and build on another and then usually end up finishing both together. Depends on how much room you have. Right now I have 3 going. That gets to be too much at times but I had a huge one come in that I just had to finish, and when I had carple surgery, I could only do some things so I got one plane to the point of needing sanding, then started another. Gotta work on the parts that interest you and then build momentum to finish the other.
