[link=http://www.cheetahrc.com]
Cheetah RC Cheetah RC Cheetah RC Cheetah RC Cheetah RC[/link]
[/link]
Designed by the UK's top show pilot, Ali Mashinchy. At 70" wingspan and 71" length, this is possibly one of the largest HARDCORE 3D aircraft on the market. The Cyclone has a THICK airfoil section for super slow, stable 3D flight characteristics.2 models in 1...perform extreme freestyle maneuvers with ease, then flick the rates for precise F3A flying.......a TRUE hybrid aircraft. Be ready for a large box at your doorstep...the wing is already joined at the factory as a one pc unit. Yes, the box is 6ft tall. When you see how large the ailerons are on the Cyclone, you will be floored. Comes out of the box pre-covered as seen in the pictures, featuring painted fiberglass cowling and pants, pull pull system, and full hardware.
We felt the need for a model that utilized all the superior tracking and precision of the Rush. With its stretched fuselage and increased side area. But at the same time gave a out of this world flight envelope by coupling it with a thicker symmetrical section that generated huge amounts of lift that allowed 3d flying to be performed comfortably at ridiculous speeds. All with the confidence of knowing that wing section would not bite you just the wrong moment and leave you stranded with zero speed and even less altitude.
To make things just that little bit better we made the cyclone just that little bit bigger. This allows the pilot to use the bigger than average two or four stroke motors. This way the model can be flown with a motor that is working well within its limits but still producing mind numbing power to weight performance.
Stir up a storm at your local strip. Unleash the Cyclone.
Another designe by the UK's top show pilot, Ali Mashinchy. Huge rudder allows non stop knife edge loops. 2 models in 1...perform extreme freestyle maneuvers with ease, then flick the rates for precise F3A flying.......a TRUE hybrid aircraft. Nice pull pull system included. High contrast top/bottom color scheme. Full hardware including matching sheets of iron on covering in case of repairs.
This truly is the plane that fly’s as if it were twice it size.
The rush was devolved as a 50 size model without compromise. The potential for massive control movements allow the rush to excel at 3d flight, but at the same time the generous side area and overall light weight mean that the rush is just as at home being flown as an everyday club model. Its mild mannered characteristics make it suitable for a wide range of flying skills.
We worked long and hard to get a small plane that not only tracked as well as its bigger counterparts, but also allowed effortless knife edge flight. Models of this size are just not meant to be this easy to fly.
Never before has such stability at slow stalled states been seen in such a small model.
Get that rush back into your flying again.
