I ordered this sub from an online hobbyshop, took about 3 weeks to deliver!
Specs: Lengh: approx. 19 in
Beam: 4 1/8 inches with diving planes extended
Height: 5 7/8 inches including periscopes on conning tower.
This sub works with a pump ballast system. The pump empties water in and out of the ballast tank, at first I wanted to make this sub a dynamic diving sub but the back diving planes kept on having problems. With the front planes above the waterline, the only way to make it dive was to use the pump method.
I converted this sub to not yet Rc from the 1/144 Trumpeter Kilo Kit. Pretty small for an average RC sub but it's cool in its own way!
> Martin, I do have a WTC installed (I'm moving this Saturday so I couldn't take pictures) because space is a problem, several times I encountered fit problems. I use a nice brass rod for the prop. Martin, I noticed you put up a new post about painting your Alfa on the SubComm BB. Basically I used water based acrylic color paint, there didn't seem to be a problem, you get a nice shining effect too.
