RCU Forums - View Single Post - HELP! propeller ducting question
Old 06-30-2004 | 07:57 AM
Johng
Default RE: HELP! propeller ducting question
Well, you should figure out a couple of braces so the prop won't hit the sides.
Now, to make the best of this setup, install your shims, which I assume are foam strips to fill the space around the hole. It may be easier to sand the round corner into the shim before putting it in. Just knocking the corner off won't do, but making a big giant radius isn't necessary either. maybe .25" radius.
