RCU Forums - View Single Post - snap's out of loop
Old 08-21-2002 | 01:33 PM
HighSierra's Avatar
HighSierra
Default snap's out of loop
Nature of the beast.... pretty much all aerobativ planes will snap with too much elevator. My Tip is to setup your low rates on your elevator so that the throw is low enough that even if you panic and pull full elevator it won't snap. Use your high rates when you're 3Ding the plane and remember to switch back to low rates when you build up speed.
