RE: question on pinning
I like to pin through the part until the balsa gets so small that the pin tends to split it. The splitting normally doesn't come into effect unless you're pinning 1/16th thick by 1/8th wide cap strips, or the like. You can buy different guages of pins if you care to keep them sorted for those different sized balsa projects.
