RE: So many Micro Systems to choose from...
How do you mount the MJ servos? They don't have a mounting flange like a traditional servo does. That Motorcalc program recommended for my application that I use an Astroflight 010, which is brushless. Since brushless motors require a specialized ESC that probably comes with the standard JR/Hitec plug, how can I make it work with the JMP connector receiver of the MJ system? The MJ receiver just has a standard BEC circuit that will work with any ESC, right?
