RE: I FINALLY BUILT MY OWN SUB FROM SCRATCH!
petn7,
Just checking to see if you had a sea test and how the sub and WTC worked for you. I am thinking of copying your idea since can't see if there are any miosure probs w/pvc WTC. Do you think using plumbers tape around the threads of the top will make it a little more water tight or just a wasted step? Also what width bottles did you use? One last question, Where did you get the motor cover case? Again the WTC and sub look great.
