RCU Forums - View Single Post - HELP !! Giles 202 Handling problem
Old 07-14-2004 | 02:12 PM
rfw1953
Default RE: HELP !! Giles 202 Handling problem
Sean, glad things worked out and thats all that it was. While you guys are at it, there are a few mods you might want to consider to add strength to the fuse and the wings. The fuse on this model has a history of flexing at the formers fore and aft of the wing saddle. The first signs of this will be a slight cracking in the covering. Place tristock strips with epoxy on both side of these formers to keep the airplane fuse from breaking in two in these areas. It's happened too often.
Also, peal back the covering on the wings in the area of the wing saddle and add some fiberglass cloth. I used finish epoxy for resin, which worked very well. I never had a problem with this after doing these simple mods.
Good luck and hope this helped.
