RCU Forums - View Single Post - Trumpeter Kilo Submarine
Old 07-18-2004, 05:30 AM
Captain Nemo12
Captain Nemo12's Avatar
Default RE: Trumpeter Kilo Submarine
>jim1221160
The pump is homemade (I'm a do-it-yourself kind of guy so that doesn't really break the rules or anything!) the pump is made of two circles of styrene with PVC bordering (looks like a flat cylinder) Two holes allow water to sip in and out. Inside, there is a fan powered by a small motor to regulate the flow of water. The sides of the pump is transparent, so you can actually see what it's like INSIDE!
>RockGuitarist109
Depends on what you mean by "frame" The kit came with the hull and control surfaces (I had to modify them for RC operation).
If you want to see the kit's build-up go here: http://captainnemo12.tripod.com
Keep you guys posted on the project!
