RE: Homelite XL Auto Oiling Saw?
Another thought, Keith. If your going to use the starter,the prop will have to run off the other end of the clutch side of the crank. Causes a few problems. The prop will run in the wrong direction. Need a reverse pitch prop. I think the thread on the PTO side is left hand pitch. Most adapters are made for the flywheel side. Muffler would probably need to be shortened up. Would be much more practical to run it off the mag. side and hand start it.
