RCU Forums - View Single Post - Trumpeter Kilo Submarine
Old 07-18-2004, 06:58 AM
Captain Nemo12
Captain Nemo12's Avatar
Default RE: Trumpeter Kilo Submarine
A few pictures can tell more words:
First picture, looking aft from the rear wtc, you can see the motor inside the bottle, the black object is the water tight seal, to make the the prop run better I simply grease the hole for the shaft or simply the shaft itself (brass tube). The white stuff is glue gun glue. It is not waterproof so I simply sealed it off with CA.
Second picture: WTC layout, from left to right.
1.Motor WTC
2.Ballast tank (black object)
3.Ballast tank pump housing WTC.
4. Forward WTC housing electronincs.
ID:	154697   Click image for larger version
