RE: Spark Plug gap ?
You should check your Maintenance Manual for the gap for your engine.
Most RC gasoline sparkplugs have a .53mm to .64mm(.021" to .025") gap.
If a gap is too small, there will not be enough space for the proper amount of fuel/air
to be ignited. If too much gap, the spark may not be able to jump across to ignite the fuel/air mixture.
