RE: My car will idol, but it stalls once I give it gas
A good whey to set your LSH is to set your HSN first. Set your throttle to about 1/4 open on your trim and leave your starter on the engine then reduse your trim until the engine starts to run rough then tune the LSN until it runs smooth continue this until you reach the idle postion. then remove the starter and open the trottle as fast as you can if it cuts out then richen it up if it bogs down the lean it up.
