Old 07-20-2004, 09:08 PM
Captain Nemo12
Captain Nemo12's Avatar
Default RE: Trumpeter Kilo Submarine
In the process of redesigning the ballast tank now, I found the following problems with the old one:
- There were two instead of one because I had to stack them up between a brace.
-The holes cut were too small
-the tubes used are too thin
The new ballast tank will be mostly located on the bottom of the hull, leaving space on the top for other equipment.
I will make a diagram showing how the sub will dive and also a drawing of the ballast tank.
