RE: DeHavilland Mosquito
codimasta
Thankyou for your input on the Mossie, I look forward to more in the near future.
I am near completion on my (first) Mosquito. It is distributed by Flair here in the UK but it is the same model - luckily with all plywood centre section.
A few details:
- I bought the mechanical retracts, an option from Flair. They work well and are easy to install (although they did foul the tanks).
- 2 X SC 36 2-stroke engines
- pull-pull on the rudder as codimasta suggests
- carbon rods to the elevators (had I thought about it the eleator could have all internal controlled movement as well)
- 10oz 2000mah battery right up front
- 11lbs dry
Bit worried about the COG. I am going to try 112mm back from leading edge of the outboard wings - which brings it exactly at the front edge of the joining tube - any advice on this much appreciated!!
I've not flown a plane with flaps before nor a twin and the engines are brand new so its going to be interesting!
Cheers
Chris
