RE: Servo Torque Calculator
The program Matt suggests is very good. I have found it to be very detailed and informative.
You mentioned " mechanical advantage " and other programs not making concessions for same. Mechanical advantage would be an application consideration verses a calculated or assumed need. The programs suggest the amount of torque and or force needed for a specific size control surface at a given speed. How you provide or realize the suggested numbers is another consideration.
