RE: OS 61FX Engine Problem
Also switch to an OS 8 glow plug. I have 2 of these engines, and so long as the tank is properly isolated from vibration, bubbles in the line are not a problem. The OS 8 is a hot plug and will sustain a very smooth idle. Like henry* said, check the lines for holes and richen the mix a bit also.
