RCU Forums - View Single Post - Deviation from thrust line
Old 07-22-2002 | 06:56 PM
Volfy's Avatar
Volfy
My Feedback: (23)
Default Deviation from thrust line
I generally try to avoid crossposting, but since I haven't had any taker in the aerodynamics forum, I figure I will try my luck here.
If I mount the engine such that the thrust line deviates from that which is drawn on the plan, what corrections, if any, should I make to compensate? Obviously I would need to adjust the fuel tank position to center with the carb. But would I have to adjust the downthrust also?
Specifically, the 4*60 I'm building calls for 2 degrees down thrust. If I move the thrust line farther up (mounting the engine higher up on the firewall), would I need to decrease or increase the down thrust angle?
How about incidence angles, any changes necessary there?
Thanks.
