RCU Forums - View Single Post - Removing annodizing?
Old 08-03-2004 | 06:40 PM
fhm101's Avatar
fhm101
Default RE: Removing annodizing?
It really depends on what the quality of the anodizing you are trying to remove. most of the crap on RC parts is little more than a dye coat being called anodizing. This is the stuff that comes off with oven cleaner. if you have true color anodizing it's a bit tougher and may even require an acid dip to remove. If you are trying to remove hard coat anodizing, good luck.
