RE: I need help with this EVO programming challenge
Go into the controls menu, and adjust the travel value there. There is a control travel value for each flight phase. All phase programming is done in the controls menu, you will see a little number next to any parameter that can be set per phase, the number tells you which phase you are currently in.
H.
