On color schemes, there is a RC model wed site,
www.seabees.com that has some great color schemes and ideas that you can use on a Fokker D-VII.
http://www.ask.co.uk/ix.asp?q=fokker...%2Ehtml&adurl=
Go to the manuels section and look for the Fokker D-VII
This will take you to a link and click on PDF down load, You must be able to view a pdf file or it will not work. You can even print this out. It has sveral different color schemes and a way to make a bungee landing gear system real easy if you would like to go this route.
I have several books on the D-VII that show a wide varity also, might be able to scan and burn a cd if anyone is interested.
Les
