RE: Pull Pull Rudder - Rods or Cable?
Cables because, if there is the slightest error in having the pivot points ahead of or behind the hinge line, the rigid rods will cause excessive servo current. Using cables, if you set it up so that the non pulling line goes slightly slack at extreme positions, you will still have positive control and no servo problems.
