RCU Forums - View Single Post - Anyone have this problem? (Trainer Question)
Old 08-16-2004 | 01:37 PM
britbrat
Default RE: Anyone have this problem? (Trainer Question)
Assuming that you have removed the anti-stall tips, & that you are running flat out full throttle -- cranking up the control throws will help somewhat. More speed helps too -- if you put a .61 in the Nexstar & also crank up the control throws, you won't be bored at all. The .61 will actually fit & the model is big enough to handle it. That combo is very interesting on floats.
