RCU Forums - View Single Post - cant get my engine started
Old 08-17-2004, 05:28 PM
FLYBOY
FLYBOY's Avatar
Default RE: cant get my engine started
Its not a screwed up engine. If you buy a new one, you will have the same problems and risk screwing it up too. Go to the field and get help. It will run fine. If they require AMA, you can write them a check there, get signed up and be flying in 5 minutes. They will then help you set up the engine and teach you more in 1 hour than you will learn in a month by yourself!
You will be much happier!
