Areas need to be cut out into the foam to allow wooden members to be glued into the foam for the most strength. This way the piece will also be flush with the surface of the foam.
It could be cut out by hand, but a much easier way is to use a router. Dadaddyro has some pics of this process at
www.rcairboats.com that should answer a lot of questions.
