RE: Tricycle gear question.
(I just love RCU, typed in my search and found this thread!)
I had a follow up question. I have a Midwest Aerobat (high wing/semi symmetrical trainer). I just finished assembling my 2nd (new fuse). I installed a Dubro main gear. I noticed that the new gear is slightly taller than the stock one. I adjusted the nose gear (a little) to compensate, but I still have 1.4 degrees down angle. The plane is spec'd to have 2 degrees down thrust.
Should I make some effort to adjust this (e.g. modify the location of the main gear axles)?
